Xtrend ET4000 (Elicom ET-4000) (Digital Telemedia DTS8601)
PříspěvekZaslal: pá leden 04 2019, 21:48    Předmět: Xtrend ET4000 (Elicom ET-4000) (Digital Telemedia DTS8601) Citovat
Mam tu nefunkcny satelitny prijimax Xtrend ET4000. Zospodu je nalepka ELICOM GMBH, ET-4000. Podla MAC adresy je vyrobca Digital Telemedia, na doske je napis DTS8601MB.
Po zapnuti len svieti zelena LED na ethernet konektore a blika oranzova. Na seriovej konzole (J501) vidno, ze sa to dokola restartuje - toto sa vypisuje donekonecna:
kód:
BCM73580001
1 00000001
234#!@
M0
SHMOO
WLCT 0000000001
SHMOO VER MSA 16b 1.12
PKID 16020112 20120406 003B6000 003B0000 001B103F 00001C00
S300001CF
S00001400
RDLY  WL 0 0000000004
RDEN  WL 0 0000000050
RDQS  WL 0
    0000000000111111111122222222223333333333444444444455555555556666
    0123456789012345678901234567890123456789012345678901234567890123
 00 ---------+++++++++++++++++++++++++++X++++++++++++++++++++++++++-
 01 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++--
 02 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++++
 03 -------++++++++++++++++++++++++++X+++++++++++++++++++++++++-----
 04 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++----
 05 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++--
 06 ---------+++++++++++++++++++++++++X++++++++++++++++++++++++-----
 07 ----------+++++++++++++++++++++++++++X+++++++++++++++++++++++++-
 08 ------------++++++++++++++++++++++++X+++++++++++++++++++++++----
 09 ---------------------------------------------------------------X
 10 --------------+++++++++++++++++++++++++X++++++++++++++++++++++--
 11 -------------+++++++++++++++++++++++X++++++++++++++++++++++-----
 12 ---------+++++++++++++++++++++++++X+++++++++++++++++++++++++----
 13 ------------++++++++++++++++++++++++X+++++++++++++++++++++++----
 14 ------------++++++++++++++++++++++++X+++++++++++++++++++++++----
 15 ------------++++++++++++++++++++++X+++++++++++++++++++++--------
P  WL 0
 00 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++
 01 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++++
 03 -------++++++++++++++++++++++++++++X++++++++++++++++++++++++++++
 04 -------++++++++++++++++++++++++++++X++++++++++++++++++++++++++++
 05 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++++
 06 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++
 07 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++++
 08 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++++
 10 --------------+++++++++++++++++++++++++X++++++++++++++++++++++++
 11 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++++
 12 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++++
 13 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++++
 14 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++++
 15 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++++
N  WL 0
 00 ---++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++-
 01 ------+++++++++++++++++++++++++++++X++++++++++++++++++++++++++--
 02 -------++++++++++++++++++++++++++++X++++++++++++++++++++++++++++
 03 --++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-----
 04 --+++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----
 05 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--
 06 ----+++++++++++++++++++++++++++X+++++++++++++++++++++++++++-----
 07 --------++++++++++++++++++++++++++++X++++++++++++++++++++++++++-
 08 -+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++----
 10 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--
 11 +++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++-----
 12 ++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++----
 13 +++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++-----
 14 ---++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----
 15 --+++++++++++++++++++++++++++X++++++++++++++++++++++++++--------
WRDQ  WL 0
 00 ++++++++++++++++++++++++X+++++++++++++++++++++++-------+++++++++
 01 +++++++++++++++++++++++++X++++++++++++++++++++++++-----+++++++++
 02 +++++++++++++++++++++++++X++++++++++++++++++++++++----++++++++++
 03 +++++++++++++++++++++++X++++++++++++++++++++++-------+++++++++++
 04 +++++++++++++++++++++++X++++++++++++++++++++++---------+++++++++
 05 +++++++++++++++++++++++X++++++++++++++++++++++--------++++++++++
 06 ++++++++++++++++++++++++X++++++++++++++++++++++++------+++++++++
 07 +++++++++++++++++++++++X+++++++++++++++++++++++-------++++++++++
 08 +++++++++++++++++++++++X+++++++++++++++++++++++------+++++++++++
 09 X---------------------------------------------------------------
 10 ++++++++++++++++++++++++X+++++++++++++++++++++++------++++++++++
 11 +++++++++++++++++++++++X++++++++++++++++++++++---------+++++++++
 12 +++++++++++++++++++++++++X++++++++++++++++++++++++----++++++++++
 13 +++++++++++++++++++++++X++++++++++++++++++++++--------++++++++++
 14 ++++++++++++++++++++++++X++++++++++++++++++++++++------+++++++++
 15 +++++++++++++++++++++++X++++++++++++++++++++++--------++++++++++
WRDM  WL 0 0000000023
WRDM  WL 0 0000000020
ADDR
 00 X-------------------S-------------------------------------------
B03B6054
567
Bol vadny elyt C901 (220uF/16V), po vymene ziadna zmena. Je tam ale len 0,96 V, co sa mi nezda. Vyzera to ako napajanie CPU - netusi niekto, ake tam ma byt napatie? Na CPU je nalepeny chladic, takze nezistim ani jeho typ...
PříspěvekZaslal: pá leden 04 2019, 23:35    Předmět: Citovat
Su tam dve flash - S25FL032P (SPI NOR 4MB) a K9F1G08U0D (NAND 128MB). Na skusku som odpojil SPI a bez nej je to uplne mrtve. Takze ten self-test (ci co to je), je v SPI NOR.
Takyto zaujimavy log som nasiel na webe z ineho satelitu s rovnakym CPU:
kód:
EBI CS2: setting up NAND flash (primary)
NAND device: Manufacturer ID: 0xec, Chip ID: 0xdc (Samsung NAND 512MiB 3,3V 8-bi
t), 512MiB, page size: 2048, OOB size: 64
brcmnand brcmnand.0: 512MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, BC
H-1
Bad block table found at page 262080, version 0x01
Bad block table found at page 262016, version 0x01
nand_read_bbt: bad block at 0x000006200000
nand_read_bbt: bad block at 0x00000ea60000
nand_read_bbt: bad block at 0x00001e420000
Creating 3 MTD partitions on "brcmnand.0":
0x000000000000-0x00001f900000 : "rootfs"
0x000000000000-0x000020000000 : "entire_device"
0x00001f900000-0x00001ff00000 : "kernel"
EBI CS0: setting up SPI flash
spi_brcmstb spi_brcmstb.0: master is unqueued, this is deprecated
spi_brcmstb spi_brcmstb.0: 1-lane output, 3-byte address
m25p80 spi0.0: found mx25l3205d, expected m25p80
m25p80 spi0.0: mx25l3205d (4096 Kbytes)
Creating 6 MTD partitions on "spi0.0":
0x000000000000-0x000000080000 : "cfe"
0x000000080000-0x000000280000 : "splash"
0x000000280000-0x000000300000 : "macadr"
0x000000300000-0x000000380000 : "nvram"
0x000000380000-0x0000003c0000 : "bootconfig"
0x0000003c0000-0x000000400000 : "facconfig"
Takze podla toho je CFE v SPI. Ten self-test je bud jeho sucastou alebo je v nejakej internej ROM a potrebuje nejake konfiguracne data zo SPI?
PříspěvekZaslal: so leden 05 2019, 16:11    Předmět: Citovat
Takze u mna SPI flash vyzera inak.
Od 0 je bootloader ("cfe"), v nom je aj retazec "SHMOO VER MSA"
Od 80000h je MAC adresa ("macadr")
Od 90000h je neviem co (retazec STARTUPVERSION=1).
Od A0000h je bitmapa ("splash")
Od 180000h je neviem co
Nad 200000h je pamat prazdna (zjavne by stacila 2MB).
PříspěvekZaslal: so leden 05 2019, 17:57    Předmět: Citovat
Stiahol som niekde ET4000_751MHz.zip a porovnal zaciatok flash so suborom et4x00/et4x00-cfe.bin. Je to zhodne. Az na to, ze v mojej flash je hned za tym dalsi kus kodu Question
PříspěvekZaslal: so leden 05 2019, 20:51    Předmět: Citovat
Ten dalsi kus kodu je pozostatok starsej verzie bootloaderu, zjavne neskodny.
Tie vypisy na zaciatku su z nejakej kalibracie parametrov RAM. Riadok 09 asi indikuje chybu. Urobil som reflow RAM a rozbehol sa bootloader. Vypis dalej nepokracuje (ocakaval som boot Linuxu), ale pripojil som to k TV a normalne to nabehlo Very Happy
kód:
BCM73580001
1 00000001
234#!@
M0
SHMOO
WLCT 0000000001
S300001CB
S00001390
RDEN  WL 0 0000000049
RDQS  WL 0
 00 -------+++++++++++++++++++++++++++X++++++++++++++++++++++++++---
 01 ----------+++++++++++++++++++++++++X++++++++++++++++++++++++----
 02 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++--
 03 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++-------
 04 -----++++++++++++++++++++++++++X++++++++++++++++++++++++++------
 05 ---------+++++++++++++++++++++++++X++++++++++++++++++++++++-----
 06 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------
 07 --------++++++++++++++++++++++++++X+++++++++++++++++++++++++----
 08 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------
 09 --------------++++++++++++++++++++++X++++++++++++++++++++++-----
 10 -------------+++++++++++++++++++++++X++++++++++++++++++++++-----
 11 -----------++++++++++++++++++++++X++++++++++++++++++++++--------
 12 --------++++++++++++++++++++++++X++++++++++++++++++++++++-------
 13 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------
 14 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------
 15 ----------+++++++++++++++++++++X+++++++++++++++++++++-----------
P  WL 0
 00 -------++++++++++++++++++++++++++++X++++++++++++++++++++++++++++
 01 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++++
 02 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++++
 03 ------+++++++++++++++++++++++++++++X++++++++++++++++++++++++++++
 04 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++
 05 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++
 06 -------++++++++++++++++++++++++++++X++++++++++++++++++++++++++++
 07 --------++++++++++++++++++++++++++++X+++++++++++++++++++++++++++
 08 -----------++++++++++++++++++++++++++X++++++++++++++++++++++++++
 09 --------------+++++++++++++++++++++++++X++++++++++++++++++++++++
 10 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++++
 11 -----------++++++++++++++++++++++++++X++++++++++++++++++++++++++
 12 --------++++++++++++++++++++++++++++X+++++++++++++++++++++++++++
 13 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++
 14 -----------++++++++++++++++++++++++++X++++++++++++++++++++++++++
 15 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++++
N  WL 0
 00 ---+++++++++++++++++++++++++++++X++++++++++++++++++++++++++++---
 01 ----++++++++++++++++++++++++++++X+++++++++++++++++++++++++++----
 02 ------+++++++++++++++++++++++++++++X++++++++++++++++++++++++++--
 03 -++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------
 04 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------
 05 ----+++++++++++++++++++++++++++X+++++++++++++++++++++++++++-----
 06 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------
 07 -------++++++++++++++++++++++++++X++++++++++++++++++++++++++----
 08 -++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------
 09 ---++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-----
 10 --++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-----
 11 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------
 12 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------
 13 +++++++++++++++++++++++++++++X++++++++++++++++++++++++++++------
 14 --++++++++++++++++++++++++++++X+++++++++++++++++++++++++++------
 15 -++++++++++++++++++++++++++X+++++++++++++++++++++++++-----------
WRDQ  WL 0
 00 +++++++++++++++++++++++X+++++++++++++++++++++++------+++++++++++
 01 ++++++++++++++++++++++++X++++++++++++++++++++++++----+++++++++++
 02 ++++++++++++++++++++++++X+++++++++++++++++++++++-----+++++++++++
 03 ++++++++++++++++++++++X++++++++++++++++++++++-------++++++++++++
 04 ++++++++++++++++++++++X++++++++++++++++++++++--------+++++++++++
 05 ++++++++++++++++++++++X++++++++++++++++++++++--------+++++++++++
 06 ++++++++++++++++++++++++X+++++++++++++++++++++++-----+++++++++++
 07 +++++++++++++++++++++++X++++++++++++++++++++++------++++++++++++
 08 ++++++++++++++++++++++X++++++++++++++++++++++-------++++++++++++
 09 +++++++++++++++++++++++X+++++++++++++++++++++++---------++++++++
 10 +++++++++++++++++++++++X+++++++++++++++++++++++-----++++++++++++
 11 ++++++++++++++++++++++X++++++++++++++++++++++--------+++++++++++
 12 ++++++++++++++++++++++++X+++++++++++++++++++++++-----+++++++++++
 13 +++++++++++++++++++++++X++++++++++++++++++++++-------+++++++++++
 14 +++++++++++++++++++++++X+++++++++++++++++++++++------+++++++++++
 15 +++++++++++++++++++++X+++++++++++++++++++++----------+++++++++++
WRDM  WL 0 0000000022
ADDR
 00 +++++++++++++++++++S+++++++++++X++++++++++++++++++++++++++++++++
B03B6054
567#!@#@
BCM97358A1 CFE v3.11, CFE core v3.19, Endian Mode: Little
Build Date: 2013-10-19 (v24)
Copyright (C) Broadcom Corporation.
Enabling NAND flash at CS1.
BCHP_NAND_FLASH_DEVICE_ID =0xecf10095, BCHP_NAND_FLASH_DEVICE_ID_EXT = 0x40ecf100
CPU speed:       751MHz
Total memory(0): 512MB
DDR Freq:        800 MHz
DDR Mode:        DDR3
MEMC 0 DEV SIZE: 2GBIT
MEMC 0 DDR Width:16
MEMC 0 DEV Width:8
Boot Device:     SPI
Total flash:     16MB
Initializing USB.
USB: Locating Class 09 Vendor 0000 Product 0000: USB Root Hub
CFE initialized.
USB: New device connected to bus 0 hub 1 port 1
USB: Resetting device on bus 0 hub 1 port 1
USB: Locating Class 09 Vendor 1A40 Product 0101: USB Hub
USB: New device connected to bus 0 hub 2 port 2
USB: Resetting device on bus 0 hub 2 port 2
USB: Locating Class 02 Vendor DEAD Product BEEF: Driver not found.
Starting splash screen.
Found splash image - Width = 600 Height = 480
Non Interlaced Replace list 043e8680 0c800000Interlaced Replace list 043e8c20 0c8005a0
Executing STARTUP...Loader:elf Filesys:raw Dev:nandflash0.kernel File: Options:(null)
Loading: 0x80001000/9611580 0x8092b93c/167636 Entry address is 0x80727370
Starting program at 0x80727370
 Velikost:  72.92 kB
 Zobrazeno:  443 krát
kybl
Založen: Nov 20, 2004
PříspěvekZaslal: ne leden 06 2019, 13:19    Předmět: Citovat
Gratuluji.Co si pamatuji,dělal jsem jednou ale et6500 tam bylo reflow procesoru.
Roman
PříspěvekZaslal: ne leden 06 2019, 19:15    Předmět: Citovat
Dufam, ze mojom pripade to nebolo tiez procesorom, lebo je hned vedla a urcite sa tiez zohrial. Ale snazil som sa fukat smerom od neho a ani elyt vedla sa nenafukol.
Inak na procesore je nalepeny chladic - keby som chcel robit reflow, tak musi ist dole a to by mohlo dopadnut dost zle.
kybl
PříspěvekZaslal: po leden 07 2019, 7:49    Předmět: Citovat
Foukni na chladič horkovzduchem a opatrně ho sundáš.
Roman
PříspěvekZaslal: so leden 12 2019, 15:04    Předmět: Citovat
Tak sa to vratilo, vraj to raz islo a po zohriati uz nie.
Chladic sa ani za tepla nedal pohnut, nakoniec som ho vypacil (vacsi plochy skrutkovac medzi chladic a dosku, podlozit nejakym tenkym plastom). Bol prilepeny nejakym silikonom. V strede chladica je vyfrezovana drazka na "jadro" CPU, akurat prilis hlboka - chladic sedi na okraji CPU a nad "jadrom" takmer milimetrova medzera, vyplnena len tym silikonovym lepidlom.
Po reflowe CPU to funguje - uvidime, dokedy. Okraje chladica som obrusil, aby sa stred dotykal "jadra" CPU, to namazal teplovodivou pastou a okraje prilepil silikonom.
 Velikost:  59.06 kB
 Zobrazeno:  431 krát
PříspěvekZaslal: pá leden 08 2021, 18:15    Předmět: Citovat
Mam to tu znovu, tentokrat uplne mrtve. Po zapnuti svieti len zelena LED na ethernet konektore (oranzova neblika). Na seriovej konzole (J501) mrtvo.
effe
Založen: Feb 12, 2005
PříspěvekZaslal: pá leden 08 2021, 18:28    Předmět: Citovat
Já to měl taky mrtvé , po druhém reflow a úpravě chladiče aby lépe doléhal to používám jako přehrávač a zatím jede .
PříspěvekZaslal: pá leden 08 2021, 23:40    Předmět: Citovat
Urobil som znovu reflow a zase to zije.
effe
PříspěvekZaslal: so leden 09 2021, 8:53    Předmět: Citovat
Ještě jsem broušením na smirkovém papíru položeném na stole snížil to vyfrézování na hliníkovém chladiči aby to odpovídalo rozměru procesoru (tuším na cca 0,7 mm) . Ono to asi o moc lépe chladit nebude , spíše placebo efekt pro mne Smile
PříspěvekZaslal: so leden 09 2021, 11:37    Předmět: Citovat
To som urobil uz minule (pred dvoma rokmi).
warp
Založen: Sep 23, 2004
PříspěvekZaslal: ne leden 10 2021, 22:26    Předmět: Citovat
Tak teď už jen zasloužené "křemíkové nebe" Very Happy
Čas potřebný ke zpracování stránky 0.68 sekund
