Mam tu nefunkcny satelitny prijimax Xtrend ET4000. Zospodu je nalepka ELICOM GMBH, ET-4000. Podla MAC adresy je vyrobca Digital Telemedia, na doske je napis DTS8601MB.
Po zapnuti len svieti zelena LED na ethernet konektore a blika oranzova. Na seriovej konzole (J501) vidno, ze sa to dokola restartuje - toto sa vypisuje donekonecna:
Bol vadny elyt C901 (220uF/16V), po vymene ziadna zmena. Je tam ale len 0,96 V, co sa mi nezda. Vyzera to ako napajanie CPU - netusi niekto, ake tam ma byt napatie? Na CPU je nalepeny chladic, takze nezistim ani jeho typ...
Založen: Mar 21, 2006 Příspěvky: 35856 Bydliště: Bratislava
Zaslal: pá leden 04 2019, 23:35 Předmět:
Su tam dve flash - S25FL032P (SPI NOR 4MB) a K9F1G08U0D (NAND 128MB). Na skusku som odpojil SPI a bez nej je to uplne mrtve. Takze ten self-test (ci co to je), je v SPI NOR.
Takyto zaujimavy log som nasiel na webe z ineho satelitu s rovnakym CPU:
Bad block table found at page 262080, version 0x01
Bad block table found at page 262016, version 0x01
nand_read_bbt: bad block at 0x000006200000
nand_read_bbt: bad block at 0x00000ea60000
nand_read_bbt: bad block at 0x00001e420000
Creating 3 MTD partitions on "brcmnand.0":
0x000000000000-0x00001f900000 : "rootfs"
0x000000000000-0x000020000000 : "entire_device"
0x00001f900000-0x00001ff00000 : "kernel"
EBI CS0: setting up SPI flash
spi_brcmstb spi_brcmstb.0: master is unqueued, this is deprecated
spi_brcmstb spi_brcmstb.0: 1-lane output, 3-byte address
m25p80 spi0.0: found mx25l3205d, expected m25p80
m25p80 spi0.0: mx25l3205d (4096 Kbytes)
Creating 6 MTD partitions on "spi0.0":
0x000000000000-0x000000080000 : "cfe"
0x000000080000-0x000000280000 : "splash"
0x000000280000-0x000000300000 : "macadr"
0x000000300000-0x000000380000 : "nvram"
0x000000380000-0x0000003c0000 : "bootconfig"
0x0000003c0000-0x000000400000 : "facconfig"
Takze podla toho je CFE v SPI. Ten self-test je bud jeho sucastou alebo je v nejakej internej ROM a potrebuje nejake konfiguracne data zo SPI?
Zaslal: so leden 05 2019, 16:11 Předmět:
Takze u mna SPI flash vyzera inak.
Od 0 je bootloader ("cfe"), v nom je aj retazec "SHMOO VER MSA"
Od 80000h je MAC adresa ("macadr")
Od 90000h je neviem co (retazec STARTUPVERSION=1).
Od A0000h je bitmapa ("splash")
Od 180000h je neviem co
Nad 200000h je pamat prazdna (zjavne by stacila 2MB).
Zaslal: so leden 05 2019, 17:57 Předmět:
Stiahol som niekde ET4000_751MHz.zip a porovnal zaciatok flash so suborom et4x00/et4x00-cfe.bin. Je to zhodne. Az na to, ze v mojej flash je hned za tym dalsi kus kodu
Zaslal: so leden 05 2019, 20:51 Předmět:
Ten dalsi kus kodu je pozostatok starsej verzie bootloaderu, zjavne neskodny.
Tie vypisy na zaciatku su z nejakej kalibracie parametrov RAM. Riadok 09 asi indikuje chybu. Urobil som reflow RAM a rozbehol sa bootloader. Vypis dalej nepokracuje (ocakaval som boot Linuxu), ale pripojil som to k TV a normalne to nabehlo
Enabling NAND flash at CS1.
BCHP_NAND_FLASH_DEVICE_ID =0xecf10095, BCHP_NAND_FLASH_DEVICE_ID_EXT = 0x40ecf100
CPU speed: 751MHz
Total memory(0): 512MB
DDR Freq: 800 MHz
DDR Mode: DDR3
MEMC 0 DEV SIZE: 2GBIT
MEMC 0 DDR Width:16
MEMC 0 DEV Width:8
Boot Device: SPI
Total flash: 16MB
Initializing USB.
USB: Locating Class 09 Vendor 0000 Product 0000: USB Root Hub
CFE initialized.
USB: New device connected to bus 0 hub 1 port 1
USB: Resetting device on bus 0 hub 1 port 1
USB: Locating Class 09 Vendor 1A40 Product 0101: USB Hub
USB: New device connected to bus 0 hub 2 port 2
USB: Resetting device on bus 0 hub 2 port 2
USB: Locating Class 02 Vendor DEAD Product BEEF: Driver not found.
Starting splash screen.
Found splash image - Width = 600 Height = 480
Non Interlaced Replace list 043e8680 0c800000Interlaced Replace list 043e8c20 0c8005a0
Executing STARTUP...Loader:elf Filesys:raw Dev:nandflash0.kernel File: Options:(null)
Loading: 0x80001000/9611580 0x8092b93c/167636 Entry address is 0x80727370
Starting program at 0x80727370
Zaslal: ne leden 06 2019, 19:15 Předmět:
Dufam, ze mojom pripade to nebolo tiez procesorom, lebo je hned vedla a urcite sa tiez zohrial. Ale snazil som sa fukat smerom od neho a ani elyt vedla sa nenafukol.
Inak na procesore je nalepeny chladic - keby som chcel robit reflow, tak musi ist dole a to by mohlo dopadnut dost zle.
Zaslal: so leden 12 2019, 15:04 Předmět:
Tak sa to vratilo, vraj to raz islo a po zohriati uz nie.
Chladic sa ani za tepla nedal pohnut, nakoniec som ho vypacil (vacsi plochy skrutkovac medzi chladic a dosku, podlozit nejakym tenkym plastom). Bol prilepeny nejakym silikonom. V strede chladica je vyfrezovana drazka na "jadro" CPU, akurat prilis hlboka - chladic sedi na okraji CPU a nad "jadrom" takmer milimetrova medzera, vyplnena len tym silikonovym lepidlom.
Po reflowe CPU to funguje - uvidime, dokedy. Okraje chladica som obrusil, aby sa stred dotykal "jadra" CPU, to namazal teplovodivou pastou a okraje prilepil silikonom.
Ještě jsem broušením na smirkovém papíru položeném na stole snížil to vyfrézování na hliníkovém chladiči aby to odpovídalo rozměru procesoru (tuším na cca 0,7 mm) . Ono to asi o moc lépe chladit nebude , spíše placebo efekt pro mne
